Chair Joinery
clark_fork
I am trying to select the best way to duplicate the rounded profile and joinery for this chair. I would also like to know if anyone has used a steam box to bend plywood as in the seat of this chair.
The Chair
[attachimg=2]
Joint Detail
[attachimg=3]
Joint Detail
I've got nothing .. but I do like that chair. Beauty in simplicity.
For the notches, you could use a large diameter roundnose or ballnose router bit and profile the crossing piece with a bullnose bit.  I'd reinforce the joint with a Domino, or a screw.
For the leg to frame joints, I'd use mortise and tenon joints.
To create the contoured seat, I'd laminate two or more sheets of plywood in a curved form - which could be as simple as clamping them over a 3/4" stick positioned right down the middle.
A vacuum bag may be worthwhile. Especially if one could pull a mould off of the existing seat.
It would probably be more along the lines of making the plywood out of thin sheets, than trying to bend a actual piece of plywood.
I like that chair a lot. I have been looking for a new project and  this may be it!  I am thinking that I wouldn't use ply for the seat...  I would use some solid wood shaped for the curve. I would also do something extreme like have maple for the body and bubinga or espresso stained hickory for the seat.
Thanks for sharing!  I will let you know if I get on with this!
Cheers. Bryan.
Cheers. Bryan.
Here is the full link:
http://www.thefutureperfect.com/seating/763-shaker-dining-chairhttp-www-thefutureperfect-com-index-php-thefutur-admin-catalog-product-new-set-4-type-simple-key-8be84e9bef0de81d4578b7d4bb5b6fa4.html
The dimensions are 16 1/2" wide
20" deep
40 1/2" High
Good luck.
Bending the plywood with steam..... I don't think I would go down that route.
It's a very small curve almost to a point where you would achieve the curve by just leaving a sheet lent up against a wall  lol
I personally would laminate to create the curve.  You would have to make it with more of a
Curve to allow for bounce back. Depending on how many layers you are going to use to build up the thickness. The more the better and the less bounce back.
i would use a router for the joints, dominos or traditional tenon. You can use router for both the tenon and shoulders like what Chris Wong suggested.
Plywood doesn't bend well with steam.  Chris and JMB are right on about laminating on a form.  Or get some veneer and make your own bended plywood.
