Earl of wood
- Oct 15, 2012
I was breaking down some plywood with my TS55. The first cut I did using pencil marks. Made a good clean cut. Then I decided to use my new Parf Dogs to make a square cut. Set it up, checked it and started to saw. Near the end of the cut I felt a little resistance but I thought the motor housing was hitting the tall Parf Dog holding the rail. When I was done this is what I found.
The setup
OH my
The result
I had cut thru the stainless steel Parf Dog. I checked the blade and found no chips or broken teeth. Festool is good.
So now I will check twice then check again.
The setup
OH my
The result
