woodguy7 said:
I am planing on ordering a cleantex ctl 26 next week. I mainly use my tools on various hardwoods, softwoods & mdf so wasn't sure if i should be going for the ctm instead. Its quite a price difference which i will stretch to if required.
The
CT26/36 brochure says:
Design approval: Dust class L
Degree of filtration, filter system: > 99%
Suitable for: Hazardous dust with max. concentration for occupational exposure > 1 mg/m3, and for NON-hazardous dust
Design approval - Dust class M
Degree of filtration, filter system: > 99.9 %
Suitable for: Hazardous dust with max. concentration for occupational exposure > 0.1 mg/m3, and wood dust
The CTM comes with a flow sensor, which sounds an alarm if the airflow drops below a certain level.
Despite the statement by Festool that the CTM is the machine to be used for "wood dust", the vast majority of woodworkers use the CTL version of the CT22/26/33/36/44/55 extractor. The filters and bags used in the CTL26 and CTM36 are the same, except that the longlife filter bag is not recommended for the CTM machine.
Apart from the flow sensor and longlife bag restriction, I am not aware of any physical difference between the two machines.
The subject has been discussed before - see the thread
ctm and ctl extractors in u.k/europe for one such discussion.
Also, on the UK site they list a "ctl 26e SD" for 433 gbp + vat & a "ctl 26e GB" for 375 gbp + vat. Anybody know what the difference is.
The above brochure also states:
With the modular plug-in system, every mobile dust extractor can be fitted with
additional modules according to your requirements: you can add a compressed
air module, a power socket with continuous current, a power socket with
automatic electronic switch-on/shut-off, or a module for connecting to a
Festool energy box.
It also lists the following accessories:
Socket module
Module SD CT 26/36
For CT/CTL/CTM 26/36; power socket with continuous current (not available in China)
496142
On/off socket module
Module SD E/A CT 26/36
For CT/CTL/CTM 26/36; power socket with automatic electronic switch-on/shut-off (not available in China)
496405
My guess is that the more expensive "ctl 26e SD" has an additional socket fitted, although I wouldn't like to say what type of socket it is.
Hope that helps a bit.
Forrest
PS. I see that jonny round boy has beaten me to it this time, with a rather more concise version of the above!
