I posted a couple weeks ago a solution using just the Kapex Crown Clamp and the Kreg Beaded Face Frame but I didn't like how the cuts were coming out so I removed the post and came up with a new solution using 8020. These are the parts I am using:
Qty: 4 -https://8020.net/75-3401.html Amt: 1.60
Qty: 1 -https://8020.net/1020.html 15 inches or 381 mm Amt: 7.80 (I might get an 18-inch piece instead)
Qty: 1 -https://8020.net/6724.html (w/o brake Amt: 68.80)
orhttps://8020.net/6424.html (w/brake 73.25)
I happen to have a flange with the break but I don't think you need it. At the time I didn't realize the difference. I also bought mine for something else so it really only cost me about $10 extra to make this work. I really wanted a solution using Festool vs buying another table or trying to wing it which is way more time-consuming. I also put a 1/4 spacer on the bottom I might make a spacer that's 1/8 instead but for now, it's working.
If you have any questions or ways to improve it please share. These cuts were quick I just need to dial in the height of the router bits but I wanted to show my progress I will work on this more this weekend.
