Due to a recent, not so positive experience with Festool in the Netherlands I want to contact you guys.
I’m a big Festool fan and I’m using satisfactory, several of their machines. I’m a small entrepreneur and not using my machine very heavily.
I need my machines to be very accurate, that’s why I choose Festool.
The problem I had, was with a planer: HL 850, I bought a few months ago. The infeed and outfeed table were a bit hollow (middle lower than sides), so I couldn’t work very accurate.
Festool in the Netherlands agreed with me about the issue, and I received a new HL 850.
This new machine had the same issues. After several phone calls, a product manager came by and offered me another HL 850. This one was used at Festool trade fairs, he told me. It was obviously used and in a used shape.
This was a no go for me. Eventually, the product manager offered me the cash back option, which I took.
The reason why I contact this forum (is because there isn't a Dutch one) and because I'm experiencing a new problem:
I’m using the CMS system, in which I use the router insert (CMS OF), and my OF 2200 router underneath.
I’m having difficulty getting the fence square on the router table. Although I can adjust the two nylon screws this isn’t working, i.e. for each distance on the scale I have to readjust the screws (over again).
The second problem is about the flatness of the insert. The CMS OF plate is bent, i.e. it is hollow, the middle is lower than the outside. When I push a block of wood, it humps, and hits the left side of the router opening, because it goes down (exaggerated).
I’ve attached two pictures to indicate my problem.
I know the first step is to get back where I bought to product, and I did that already. They told me the products will go back to Festool.
I don’t want to be a nagging customer. But after my recent experience, can someone help me in finding a good solution i.e. to get me in contact with a service employee / product developer of Festool (in Germany)?
I believe Festool makes excellent products.
Kind regards,
Gijs
[attachimg=2]
Kind regards,
Gijs
[attachimg=2]
