B bobsteele Member Joined Sep 17, 2017 Messages 1 May 30, 2020 #1 I am interested in making doors with my CMS and 1400. What is the widest I can go. The bit in the set is 3 1/8. I know many of you utilize the 2200. Have you use the 1400 on a slower setting for the large cutter? Thanks
tjbnwi Member Joined May 12, 2008 Messages 7,369 May 30, 2020 #2 Speed 2, 2 passes will work just fine. You may need to take the base off the 1400. I spin 3-5/8 panel raising bits with the 1400 or 2200. The 2200 works better due to power difference. Tom
