R robcamp Member Joined Jul 7, 2017 Messages 2 Jul 7, 2017 #1 The router table fence is to narrow to handle a raised panel bit with a cutter diam of 3 1/2 inches. Is there a different setup or adjustment I can make to work with this bit?
G geoffshep Member Joined Jun 20, 2014 Messages 146 Jul 7, 2017 #2 If you mean that the fence will not open up wide enough, have a look at this which should start at the 8m44s point: =8m44s
R robcamp Member Joined Jul 7, 2017 Messages 2 Jul 10, 2017 #3 The fence is just about 1/8 inch to narrow. Attachments File Jul 10, 4 21 32 PM.jpeg 2.3 MB · Views: 316
GarryMartin Member Joined Jun 11, 2011 Messages 1,939 Jul 10, 2017 #4 If you mean the shroud, then you can either file it away, or for the simplest solution, just add a secondary fence. Seehttp://festoolownersgroup.com/festo...maximum-bit-diameter-cms-with-of-2200-router/
