CMT forstner Bit Set
Mario Turcot
Hello all,
I am looking to get a set of forstner bits and was wondering if any of you would recommend the CMT 537.000.16 16-Piece forstner Bit Set.
I actually have a cheap Porter Cable set, and by cheap I mean really cheap. I can hardly cut into anything but pine... I know pine is fine! Anyways I am looking at a better set. Suggestions are welcome!
Mario
Just used my first CMT bit, 22 mm, drilling 72 holes, 5/8" deep, in MDF - making blocks to store router bits. Not a definitive test, but it seemed to be cutting as well on the last hole as the first.
Hi Mario,
I have had a CMT set for several years now and the bits have served me quite well.  Some sizes get used more than others- many have yet to need sharpening- but I have a file-looking sharpener made by Trend that I have used to sharpen a couple of my frequently-used sizes.  Been happy with their performance in hardwoods.
Regards,
Gerald
Thanks for the reply.
Based on Tom picture the CMT bits made away better clean cut then what I am used too.
Any one using the Lee Valley ones. I went to the local store and they can't tell what manufacturer they are from :( and they are more expensive than CMT bits.
Mario
I found an article from the March/April 2008 issue of Fine Woodworking.
They published test results for several steel bits:  Bosch, Famag, Fisch, Freud, Grizzly, Porter-Cable, Woodcraft.
  -  Best Overall went to Famag.
  -  Best Value went to Grizzly.
  -  The 1/2-inch diameter Fisch and Freud bits had some plugging.
  -  All of the 1-inch diameter bits cut cleanly.
  -  Three hottest 1-inch diameter bits drilling into hickory were:  Bosch, Porter-Cable, Grizzly.
They published test results for two carbide bits:  Freud, MLCS.
  -  The Freud bit performed better in testing.
  -  The MLCS bit has replaceable tips and creates a true flat-bottom bore (no point divot).
The price of this kind of tooling has come down so much (when made in China) that carbide versions often cost less than steel used to.
Bought a 40mm carbide tipped bit that Magswitch sells ($8.24 at Amazon) to make fixtures to hold MAGJIG 150 Magswitches.
Made nice clean holes in plywood that are so close to the diameter of the 150 that they had to be pressed in.
