Conference Table
rajuliano
I recently built a 128" x 38" conference table. The top is quarter sawn walnut and the base is solid poplar.
For the top, I used 3/4" walnut for the field and used 1.5" for the edges. For the ends, I made the 3/4" pieces long, cut them to length, and used the cutoffs flipped over and attached to the underside to give the illusion of a thicker top while matching the grain. The underside of the 3/4" field is strengthened by 2 pieces of 1/2" MDO. The MDO is screwed to the 3/4" walnut with oversized holes and washers. This made the tabletop lighter to move around (office is on the 16th floor of a highrise, so negotiating into the freight elevator was a challenge) since it was in 3 pieces.
The base is comprised of 5 main pieces: 3 pillars and 2 U-shaped troughs. There are also some nailers with oversized holes that screw into the MDO only (not into the walnut). The troughs end up hiding the underside of the network/tv/power ports accessible from the top of the table. Holes in the pillars at the trough attachment points allow all cables to run hidden inside the table to a network switch and power strip inside one of the pillars. From there, a single network cable and a single power cable exit the bottom of this pillar and plug into the wall. There are 4 leveling feet on each pillar which give the appearance of the base floating.
The base is finished with Target's EM6500 and EM9000 in a semi-gloss. The top is finished with EM9000 in satin with CL100 added.
It's my first project of this scale, so I learned a lot about organization when it came time to glue the large pieces together. Talk about stressful!
Thanks in advance for any comments!
Whoa! Huge...And gorgeous! Must have been a beast to glue up, and move around. did you do it all by yourself?
Thanks for the kind words.
Falch, I recruited my wife when it came time to glue the top. She was a great helper.
Richard
Great job and very nice end grain treatment.  The last conference table I built was out of East Indian Rosewood with a 1 3/8 thick top and that beast was a load getting up into the building.
Jack
Very, very nice table...love the grain and overall look.  Very impressive table!
Scot
Nice looking table. What are the rectangulars in the middle for, are they decoration or do they have a function?
that is one great looking table!  really love everything from design to lumber selection and layout..  the grain is beautiful
John
Looks great!
How wide are the 1.5" for the edges? How did you deal with the flipped ends where they met the edges, with a miter?
Tim
Tim Raleigh said:
Looks great!
Tim
Hi Tim,
The 1.5" edges are 4" wide. The field 3/4" boards are 7 1/2" wide and there are 4 of them. The flipped end pieces are about 4" long at each end. The flipped end pieces were glued to the underside-face, then trimmed flush on both sides on the tablesaw (obviously, upside-down).  I used Dominos to align all 6 pieces during glue up. Aside from the glue on the Dominos, the 1.5" edge pieces are glued long-grain to long-grain with the edges of the 3/4" pieces for most of the field and the full 1.5" (for 4") at the ends. Hope that makes sense.
Richard
Richard
Yes , thanks for your explanation.
Tim
What sort of treatment and or wood selection would one need to do to make something like this that would last outside on a deck as a outside dining table?
I've been thinking about building a teak strip boat 'deck' for the table top on a water resistant sheet of plywood to get rain resistance for the table top, but what should one use to build good looking box feet like this table has that would not get destroyed in outside humidity? Brown film plywood won't look very good so it would need to be painted / treated somehow to look good...
Is there space within the box legs to make drawers in there to store odds and ends in or are they filled with sand or something else to give them heft?
