Connecting Two 27mm Hoses together
lighthearted
Hi there-
I just purchased a CT 36 E this weekend and i am still finding my way around.
I bought a second 27mm hose to make a longer hose and I am having trouble figuting out the connections
This is what I thought I needed and have purchased:
Festool 487721 Hose Sleeve, Reducing Sleeve For Antistatic D 36 Hose
Festool 493047 Hose Sleeve, Antistatic Connector Sleeve
Festool 452894 Rotating Connector For D 36 Antistatic Hose
and a second hose obviously.
I removed the original fitting, but for the life of me I cannot see how these go together.
I appreciatte any help you can offer.
[embarassed]
1. This is the only right part you bought: Festool 493047 Hose Sleeve, Antistatic Connector Sleeve
The other two parts are for the wrong hose. If you have the 27 mm hose, it's no use buying the parts for the 36 mm hose.
2. You need to get the 27 mm equivalent of this part: Festool 452894 Rotating Connector For D 36 Antistatic Hose.
    Which is: Festool 452892 Hose Sleeve Rotating Connector for D 27 Antistatic Hose.
3. You don't need this one at all: Festool 487721 Hose Sleeve, Reducing Sleeve For Antistatic D 36 Hose.
