stvrowe
- Jan 27, 2007
I have just started using 0.5mm edgebanding with the Conturo and am experiencing less than an ideal edge with it even after trimming. I do not experience this with 1, 2, or 3mm edgebanding. The materials used are Rehau PVC edgebanding with white glue pucks and temperature set at the recommended 200C. What appears to be happening is the glue seems to be thermally buckling the edgebanding at both the beginning and end of the application. I have reduced the amount of glue deposited and this does help but does not eliminate the buckling. I have not reduced the temperature from that recommended.
Pictures are attached and any suggestions would be appreciated. Even after trimming, there is a very slight deformation right at the trimmed edge.
[attachimg=2]
[attachimg=3]
[attachimg=2]
[attachimg=3]
