I didn't know where to post these ideas, so I figured I'd put them here, because this thread is what inspired them. I haven't tried them yet, but I will soon. I figure that if the Dominos are sturdy enough to be used for bench dogs, they could also be used for:
(1) movable shelf supports for utility shelves (instead of 5mm or 1/4" pegs).
(2) knock-down joints for case-goods such as armoires or stand-alone cabinets. Some explanation: glue the dominos into the mortises that have been bored into the sides, but not into the mortises that have been bored into the back, top, bottom and any stretchers that span the front of the piece. Assemble the piece. Now pre-drill holes in toward some of the non-glued mortises (two or three on the each side of the back, top and bottom, depending on the size of the piece, and one on each side of one or more of any front stretchers). Drive screws into the holes you just drilled, so the screws act as removable "pegs" for the Domino tenons that are within those mortises. The screws should not be visible on the back, bottom and stretchers, but if the top is to be visible, you can cover it with a false top for appearance's sake.
