i have a few skirting boards (base moulding) to do. i i always cope the inside corners. i usually use a coping saw and fettle the profile with a round file.
i would love a RAS 115 but cant afford it . i was thinking of using my small angle grinder and a sanding pad. the only sanding pad i can get locally with out ordering one is a plastic disk with a nut on the back. it doesnt look great for the job.
can any one reconmend a pad etc that would work for me.
what i was thinking of as a sort of trial run to see how i like coping with a grinder. if i got a normal small metal grinding disk and put sandpaper on it. it should glue to the disk ok.
what do you think
what do you think
