Coping with Trion
twang120
I have done some searches on this forum, but have not been able to find recommendations for Trion jigsaw blades for coping moldings.  I will be using the Collins coping foot.  I attended a Katz radshow where Gary demonstrated using the trion to cope crown molding - really impressive.  I did not recall the blade # he mentioned, but he did say the teeth had a wide set and was very stiff.
Collins recommends a certain bosch blade for use with their foot.
You could cross reference that.
I've been using the Collins foot with my barrel Trion for a few years now.  The Bosch 244 blades work just fine.
FYI....When I received the new foot for the trion, I had to modify it slightly...  the back of the blades were rubbing on the front edge of the foot.  I just cut a kerf in the foot to accept the blade ( about 1/16", or so)  and all's good.  I don't know if this was a onetime manufacturing issue on my foot alone, or if all of the Collins need this adjustment.  Either way, it was a very easy fix.
Dan
