Correct Hose Sleeves for 36mm Nilfisk Hose
ChipMonk
I am trying to figure out which hose sleeves I need to get in order to connect a 36mm OD Nilfisk hose to Festool machines.
Here is what I came up with so far:
487721 - D 36 DM-AS Reducing Sleeve
This will screw directly onto a bare 36mm hose and then fit any tool with 36mm port.
498528 - RM D36/27-AS Reducing Sleeve
This will attach to the D 36 DM and any machine with 27mm port.
If someone could please let me know if this is correct.
Originally I was planning to get two of 768135 - DC-D 36/27-AS Coupling Sleeve (the correct part for the short 27mm hose is 487071 - 27 DM-AS 36mm Hose Reducing Sleeve) and attach them to each end of a short 27mm hose to act as an adapter to connect 27mm tools to 36mm hose.  However, the NZ importer does not offer the 27mm hose by the meter and I was not able to find any other source of 27mm hose in New Zealand.
Looks like I had the incorrect part listed for the short 27mm adaptor hose.
The correct adaptor to use when making the short 27mm hose adapter is the D 27 DM-AS Order Number: 487071.
