cliffp
- Jun 22, 2012
I recently had a problem making square cuts to a 43cm x 14cm drawer front (cutting at right angles to the long side) using the sliding table. I was getting an error of around 0.5 mm over the 14cm cut. I had previously had satisfactory results with this set up and bigger pieces. I am confident that the mitre gauge was set correctly. With such a small piece, very little of it is able to ride on the sliding table and to make matters worse, I was only trimming the piece so that only one side of the blade was doing any cutting. I suspect that the blade was pushing the piece to one side (if the blade was cutting on both sides the forces on each side would be balanced) and not anticipating this, I was not holding the piece firmly enough against the mitre fence (and it couldn't be clamped to the table) and it shifted during the cut. I am wondering how to avoid this problem in future and am considering making a cross cut sled that registers along the rip fence (I have the good, so-called LA stopper). I would be interested if anyone has any suggestion as to whether this would be any good or whether there are any better solutions (I don't have a Kapex). I know people don't generally use the rip fence when cross cutting but that is because in such cases people are usually registering the piece to be cut against the fence which is dangerous - in my case, it would only be the sled that made contact.
