CSC SYS 50 Dust Port Connection
Chainring
SF Bay Area
I had read of the 36mm hose being on the tight side when used on the CSC SYS 50, specifically when setting angles it would create friction. Looking at the outlet port on the saw, I noticed it looks the same as the outlet on my TSC 55 when the swivel connector is removed. Sure enough, the swivel connector (Angle piece, 202096) fits. If it's twisted on all the way, it's a bit of a bear to remove, but nothing too terrible.
Anyone with a TS 60 K and CSC SYS 50 willing to try that swivel connector? That swivel connector is part number 10703935.
The connector from the TS60 also fits.
As mentioned, the connectors are difficult to tighten and loosen on the CSC SYS 50, and it must be removed to for the lid on the saw for transport. I wish there was a better adapter for the saw.
Thanks for the info on the TS 60 connector. I'll purchase one or the other, whichever is less expensive. For the snug fit, I'll probably knock a bit of plastic off the twist lock on the swivel connector.
