fletchtool
- Nov 22, 2011
Yesterday I took the CT Midi I had just bought last week back to Lee Valley to get a CT26E. I had decided I wanted an extractor that I knew (all the comments on the FOG) would accept the Ultimate Dust Deputy or if I decided to put off getting the UDD, had the capacity (6.9 gal) to handle the volume of sawdust dust from my table saw without having to change bags too often. My goal is to be able to use my table saw inside my garage (which is really now just a storage area) during the winter without getting sawdust all over everything. This evening I decided to hook up the CT26 directly to my Bosch 4100 table saw with adaptors I got from Lee Valley. I was really excited to see how clean the saw would run. The outcome was less than satisfactory... When I ripped some 3/4" maple, there was more sawdust on the saw table, floor and my work bench than in the CT26. The passive Bosch dust bag that I hooked up next was more effective than the CT26; the transition from 2 1/4" output on the Bosch to the narrow intake on the CT26 vac hose kicked the saw dust back in the saw. I had a silent inkling this might be a problem, but just expected the CT26 would extract all the dust from my table saw because Festool tools work so well. I hooked up my 4 gallon Rigid shop vac with 1 ¾” hose attached to the saw with masking tape and although not perfect, it was much better. The CT26 worked better with the 1 ¾” hose attached with masking tape to the saw too. I am disappointed about having to purchase an additional length of 2.5" hose and connections in order to have the CT26 do this job. Maybe I should have just used the Rigid shop vac for my table saw and the Midi for sanding and jigsaw use. I guess I got caught up in the excitement of new tools.
