I was just given a non working CT36 E AC vacuum with accompanying 36mm hose and vacuum kit.
I was wondering if replacing the electronic board would fix it, and if it would be worth it as EKAT says the replacement board for the vacuum model is almost $500, new vaccum is $1800...
With the power knob [big grin] on either auto or manual the 3 pin outlet works (240V), but the vacuum will not turn on.
The person who gave it to me pulled it apart, and then lost the cover plate for the adaption module and the plug for the motor lead ( he plugged the leads into an 18v battery to see if the motor worked ( which he said it did).
However now i dont know if the cables are polarity dependant or if it doesnt matter which way they go back into the main board.
On the pics both Capacitors seem to be toast but as posted in another thread i dont think ill win trying to remove the resin.
I guess im asking should i risk 1/3 of a new vacuum on a motherboard that MAY fix it..
Cheers
Cheers
