asherbrand@gmail.com
- Oct 16, 2016
I have a 3 year old CT 48 Dust extractor that has seen intermittent light use. In the middle of using the track saw the vacuum stopped working. I was using at TS75 which continued to run (powered through the CT48). The vacuum will not turn on, however, it is possible to run a tool through the vacuum. The vacuum was not hot and had been used intermittently for an hour or two. Any ideas on what might be wrong? Probably a circuit board problem or something...
