CT 48 will not power on
wchamil
I was using my CT48 with TS75 and I lost power to both.  The circuit breaker in the garage isn't tripped but I can't even power the CT48 on manually.  Is their a circuit breaker/fuse within the dust extractor?
The TS75 powers on if I plug it directly into the outlet in the garage.
It is conceivable that if you had been using it for a while that the thermo protection might of cut in.  Might want to wait and try it again.
If not the thermal cutout, you may want to check the actual selector switch.  I've had one get dirty on  a CT , and that made it cut out.
I've also had one plugged into a receptacle on a jobsite that had a hairline break in one of the loops to the terminal and that caused the vac to turn off intermittently.
Boy was it fun and time consuming figuring that one out.
