CT Midi hose
mike9
I need to purchase a new hose for my CT Midi but I am not sure what model to order. My vac has the 90 degree connector going into the vacuum itself. I looked at one hose but it said it would fit 2019 and newer but have no idea when I bought my vacuum or where I can find a date on the unit. Thanks for looking.
The 2019 MIDI moved the port forward closer to the front, but still in the garage.  It also got recessed deeper into the body, hence they now use a straight connector and just bend the hose.
Regardless, your serial placard on the back will have:
Voltage | Amps
Total amps | IP X4 | weight | date mfg
T-Nr | S-Nr
  D32/27 hose with right angle connector 500680.
  Or if you want a straight D27 hose the one for the CT-SYS (201665) has a right angle connector but it is also about 1 1/2' shorter.
