- Nov 18, 2010
Steve,
Thanks for getting to the bottom of this for us. I had the same concern.
Jeff Zanin said:That seems quite reasonable and incorporates the common sense aspects of Brice's comments with an appropriate scope limitation.....
Pete Pedisich said:I have used my CT22 with the OF1400, TS55, Bosch 13amp circular saw, DW 618 Router on a 15amp circuit, never a problem. I never use an extension cord with my CT22 or my 6 gallon compressor, but tradesmen have no choice often.
Anyone know if the 120 vs 240v issue gives us (in the US/Canada) less real world capacity in the tool receptacle on the CT's?
The basic formula is E=IR. E the voltage, I the current and R the resistance. Doubling the voltage, halves the current while the internal resistance of the CT remains constant, so makes no difference for current draw of the attached tool.
** Nobody from Europe has told us what the max amperage draw is on their CT that runs on approx. 230vac. **
Alex said:Guys, just get a 230 volts net, all problems solved. [tongue]
...or forget about using the CT altogether and call Merry Maids when your done.
Ken Nagrod said:** Nobody from Europe has told us what the max amperage draw is on their CT that runs on approx. 230vac. **
Ken Nagrod said:That's why I was curious as to why no one from Europe or other areas that run on 230vac letting us know what their CT's warning label states
Alex said:Ken Nagrod said:** Nobody from Europe has told us what the max amperage draw is on their CT that runs on approx. 230vac. **
That's because we never use amps in relation to power tools like Americans do. We always use watts over here.
That's because we don't have any warning labels on our power tools like Americans have. We always just use them until they explode. [embarassed]
Anyway, I don't know what the limit is on the CT's. I know I have used my 2200 watts CS70 on the CTL Mini, the CTL 22 and the CTL 26 without problems.
