catchy_username
- Nov 2, 2023
First post here, but I haven't seen any user feedback from users here in regards to the cordless Midi.
I have owned one for a while now and I have mixed thoughts on it.
Firstly, the Pros:
The suction is really good. Rivals a corded Midi, at least while the batteries are full.
It's basically a corded Midi, but even more maneuverable as it does not have a cord. It's amazing moving it around and not running over a cord or not needing to worry about a cord.
Build quality is typical Festool dust extractor quality. Solid and it feels like it could take some abuse.
Now, the Cons:
It's a $679USD/$869CAD Vacuum. Why on earth is it using a brushed motor? Pretty much any BLDC motor is more efficient than a brushed motor, which would mean similar/better performance for less power consumption. I'd understand brushes for a corded vacuum but for a cordless vacuum, it feels like they were just being cheap. Not only that, but the motor unit is a sealed unit (unlike the Corded CT Midi/CT26/36/48), so you actually need to replace the entire motor and impeller unit (which they call the turbine), once the brushes wear out. On a normal Midi you would just replace the brushes.
The 8AH battery does not exist in North America, making this vacuum effectively useless for anything that is not a quick cut. I get it was designed for that but more runtime is better. Heck, an AC Adapter like the Metabo HPT Multivolt adapter would make this thing a class leader, allowing for corded/cordless work. I feel the 8AH being high current 21700 cells would also fare better and result in more consistent suction power (around ~30% remaining battery there is a noticeable dropoff in suction power, when using 2x 5.2AH batteries).
Also, what on earth were they thinking? The battery compartment lid is about 2mm too recessed in to the vacuum, meaning that if you have any systainers on top of the vacuum, you actually cannot change the vacuum batteries without taking off the systainers. This is probably the biggest pet peeve of the vacuum. I might have to take the battery compartment lid off.
All in all, it doesn't feel as well "thought out" as most Festool tools are to be honest.
Firstly, the Pros:
Now, the Cons:
