Festoolfootstool said:Hi all anybody know what the max load is on the onboard socket on the110v ctl 26
Festoolfootstool said:hi Forrest.thanks for that, I am suprised by that, its not much use is it. its no better than my ctl mini. so what extactor would you use with a of2200
Festoolfootstool said:Festool.........I thought it was a SYSTEM..................... cheesed off
Festoolfootstool said:Well I was going to buy a ctl 26 on monday but I think thats on hold.........I was suprised when my mini arrived to see the 500watt max sticker when all the info I found said 2400 wat max socket load which is why I thought I would did a little deeper as the same 2400 watt spec was given for the ctl 26.
Rob-GB said:Thanks for all the effort to help get to the bottom of this dilemma, guys. It has now been resolved. [big grin]
The following is a reply from Festool UK, I have edited out email addresses for obvious reasons and hope this post will help others as it is apparently a common question! [eek]
RE: CTLMini Wattage
Sent: 24 November 2009 14:37:02
To: *****.co.uk
Good Afternoon Robert,
It is 2400w for both 110v and 240v. The sticker that states 500w is something that is done in our head quarters! This could be for other countries but for GB this is incorrect!
It is very safe to use your 110v TS55 with this 110v extractor.
Hope this helps,
Kind Regards,
C********
So It looks like I'm all set to go and suck sawdust ;D
Brice Burrell said:Festoolfootstool said:Well I was going to buy a ctl 26 on monday but I think thats on hold.........I was suprised when my mini arrived to see the 500watt max sticker when all the info I found said 2400 wat max socket load which is why I thought I would did a little deeper as the same 2400 watt spec was given for the ctl 26.
You really should have read the links provided. I'll be kind enough to save you the trouble. Here is a reply from Festool UK about the 110v Mini's wattage taken from Rob GB's post.
RE: CTLMini Wattage
To: *****.co.uk
Hope this helps,
Kind Regards,
C********
I'm sure the CT26 and CT36 are the same. Otherwise there would be no point in selling a vacuum made to be used with power tools if it can't handle the wattage.
Alex said:Festoolfootstool said:Festool.........I thought it was a SYSTEM..................... cheesed off
I think it has to do with the 110 volt system, and not the Festool system.
The power a machine draws in watts is defined as watts = voltage x amperage. If you have half the voltage you need double the amperage to get the same power to the machine. It is the amperage that makes electric wires run hot, not the voltage. Since all Festool tools are basically designed for usage on 220 volt systems, and not 110 volt, the wiring is not sufficient enough to sustain the higher amperage needed with 110 volt systems.
So before complaining about Festool, complain to your government and ask them to abolish the 110 volt system. It's completely redundant and just causes a lot of headaches. Here in The Netherlands and Germany we only have 220 volt and never a problem whatsoever.
Hi as I understand the armatures and field coils are wound differently for 110v and 240v machines
Festoolfootstool said:Alex said:Festoolfootstool said:Festool.........I thought it was a SYSTEM..................... cheesed off
