CTM 26 E GB
Avtandil J
Hello to everyone
I'm new here, I did use the search but couldn't find the solution.
If anybody had the same issue with this version.
Problem is that is beeping after few seconds of working. It's quite new, everything is working but this beeping is very annoying. If I put settings of house to lower than sometimes it it doesn't beep.
I know that it has airflow sensors but why is beeping I don't understand
If it beeps it means the sensor detects the airflow is too low. This generally means you have to replace the filter bag. But due to the nature of certain types of dust, bags can become clogged long before they are completely full.
You also have to put the hose size selector switch to the proper size of the hose you have. Festool's hose size is named after the inner diameter of the tool-side nozzle, and not the outside diameter of the hose itself.
For troubleshooting, take out the filter bag, the main filter, and take the hose off. Run the vac and see if it still beeps. If not, add the main filter back and try again. Then add the hose and try again. Finally put in a new filter bag and see how it works now.
If the problem still persists it might be that the sensor of your vac is dirty or clogged, or simply faulty. In that case, contact Festool service department.
demographic said:
Is the bag full or the hose blocked?
Nor bag is full, neither hose is blocked. I don't know. I tried to troubleshoot. Took of bag and main filter and still beeps. It's almost new
