LaserGecko
- Jan 26, 2007
A couple of quick questions...
MFT: Should the guide rail support be torqued a little to get it "latched"? I checked it with my squares and assume this is so. Everything is butted up against the factory stops and I'm reluctant to change them.
RO150: How hot should the rubber padded, handhold area get? It seems like mine gets hotter than it should.
Hose & Cord Deflector: I take it these are still the ones designed for the old version of the guide rail since it looks "off" by about a half inch.
OF1400 on Guide Rail & Dust: I made a 1/4" dado into MDF with the Guide Rail adapter. The amount of dust generated was astounding. I take it the gap created by the outrigger pretty much nullified any vacuum created by the CT-22. A later freehand rout with the base firmly on the MDF created the expected amount of dust (little to none).
Par for the course???? Since I'm going to be doing a lot of these dados, it looks like the secondary baseplate might be in my future.
Comments/answers appreciated!
Thanks,
Thanks,
