Slartibartfass
- Apr 25, 2014
Michael Kellough said:Thanks Slarti...
[member=297]Michael Kellough[/member] you must be close by to where I live (Mamaroneck). If you want to take a peek at the jointer PM me....
yetihunter said:Some info on Cutech (besides that one guy that was spamming Lumberjocks
a while back):
http://www.woodworkersjournal.com/cutech-tool-meet-new-kid-block/
The factory had previously made some very well received planers for
Ridgid, Steel City and etcetera.
Good info and an interesting point. Thanks for bringing that up.afish said:I wish they would have used a standard carbide insert. 14x14x2 is very standard and can be had easily. It looks like they use 14.25x14.25 size which is an odd size to me and looks much harder to source. Not sure if thats on purpose or not to make you buy the inserts from them. I would worry more about future availability. Lots of things use the 14mm so they will be available long into the future.
Vtshopdog said:The Cutech company has rebranded as "Wahuda Tool" and current models have cast iron tables rather than aluminum and cutters are 4 sided now. They appear to be having Covid type supply chain issues like many manufacturers.
Vtshopdog said:I've owned one of their segmented head thickness planers for several years. It's been very good, relatively quiet (for a planer!!) with great finish. Dust collection is really pretty good, no complaints. My only quibble is the black coating on the feed tables is wearing away a little exposing a polished surface. Appears cutter design is the same on planer and jointer.
Regarding replacement inserts, there are substitute blades available on Amazon for $20-something per 10 pack (mine needs 12 inserts, gotta buy two packs....)
I've considered their bench top jointers and view their website now and then. The Cutech company has rebranded as "Wahuda Tool" and current models have cast iron tables rather than aluminum and cutters are 4 sided now. They appear to be having Covid type supply chain issues like many manufacturers.
afish said:Do you have a link ? I did a quick search on Amazon and didnt see any 14.25x14.25 inserts.
