I upgraded from the smaller MFT800 to the full size MFT1080, and I finally figured out that I can now cut 48" wide material. Anybody have a tip on how to make sure it is square? (using the table system, rather than just marking things out with a framing square.)
I've been using 20mm bolts (as bench dogs) in the table top to align everthing else (including the swivel unit clamp things), but I run out of table for 48" material.
Is there some way to align things to the edge of the table? (I only need things accurate to about 1/16" in 48"). I tried using the Combination Angle Unit, but either I'm not using it correctly, or else it has too much wiggle because I was off by about 1/8".
