I need to install a 30cm metal speaker grille/cover vertically into some plasterboard (sheetrock) above head height. The plasterboard has nothing behind it. It's supported elsewhere on some battens.
What's the best way to cut out the hole and also recess the edge a little so that the 5mm thick cover will sit flush with the plasterboard? It has to look very neat. I was thinking about using the Festool OF1010 and the tramel attachment to first cut a 5mm rebate at 300mm diameter, then a smaller hole of about 290mm diameter, so that it sits flush.
I think it would work but I'm a bit worried about using the trammel and router vertically and while up a ladder!
