pugilato
- Mar 31, 2011
I have a project to install four louvered mahogany doors. The first door was way oversize (by 7/8" on each side, 1/4" on the bottom), so I set up the TS55 to zip right through these. The rails and stile are solid mahogany, 1 3/8" thick.
Well, I found the TS55 somewhat lacking in power (or perhaps it was the blade). After the first interminable cut, I had to sand the new edge with my RO90 (80-220 grit because of the burn marks). After considering the situation, the best I came up with was to use the router approach, namely, set the depth of the TS55 make the rest of the cuts in depth increments, without moving the rail. That worked real well and did not have to deal with the burn marks as much. Another approach I thought of was to go all the way through, but short of the mark, then slide the rail to the mark, and finish the cut with a very narrow piece to cut (maybe 1/8").
Is there a better way?
