Looking for suggestions on which of the options I already own would give me the best results cutting 80/20 extruded aluminum. Options I'm considering:
1) TS75 with the metal cutting blade - my hesitancy here is that the blade says it's for cutting steel not aluminum. Has anyone used this for 80/20?
2) HKC55 - I own the standard, fine, and rip blades. I understand they make a metal blade, but would have to locate it and then that's something to buy.
3) Kapex with the standard blade. I'm not sure I will do this often enough to justify the $150+ for the metal blade.
4) I also have a Milwaukee 6 1/2" circular saw for which I could probably find a blade.
I'm planning to build some benches and jigs so I'd like a fairly clean cut, but likely won't be cutting aluminum often so would prefer not spending more than I need to. Any suggestions are appreciated!
Thanks,
Guy
Thanks,
Guy
