Cutting Aluminum Extrusions with the Kapex?
festoller
I am planing to cut some aluminum extrusions (80 x 80 x 6 mm 90? angle extrusion) on the Kapex with the proper aluminum blade #494607 and I could use some advice!
What would be the recommended speed and cut technique and how do you handle dust collection? I do have a Dust Deputy between the Kapex and the vacuum, but I guess the aluminum cut off can get pretty hot. Would you recommend cutting with or without vacuum?
I would probably go for just over 1/2 full speed if its a fine blade and collect the chipings after cutting not during. with the vacuum if you have some waste do a test cut before cutting proper
The Spark Trap is designed to catch hot stuff.
It also works well to knock down chunks so they don't go through the back of the bag.
EDIT:
What I meant by chunks is I think most people find more use for the Spark Trap as a mechanism to knock down things that could go through the back of the bag if allowed to keep going. Imagine you are picking up chips of tile or mortar.
worth buying if you are cutting metal regularly but they do cost quite a bit
Use stick wax on your blade.  Feed slowly -- especially as the blade is about to break through the backside of a surface -- to prevent kickback.  I would also agree that you should vacuum afterwards -- vacuuming hot chips without a spark arrestor could be a problem with wood dust in you bag.
Be sure to wear safety glasses that provide full coverage.  Many, many years ago I got an aluminum sliver in my eye while cutting even though I was wearing safety glasses.  An extremely small chip somehow entered around the side of my safety glasses, bounced around the inner surface of the glasses and became stuck in my eye.  My eye doctor could not find the chip.  I insisted it was there and directed him to the location.  He finally saw the chip and removed it and showed me this very tiny spec of aluminum -- felt huge to me before he removed it.  So, do take care.
Using the proper blade will be the most important thing to do. You may want to dial down te speed, as suggested. Scoring a candle just before cutting the profile will help preserve yor blade - the aluminum won't stick to the carbide teeth as easily. Let the blade come to a stop and clean off the excess, so as not to create an ignition source.
Don't worry to much about the heat in the swarf - if you have a long enough hose, the swarf will be more then adequately cooled before it hits the bag. Remember: the energy you put in the swarf is relative to the mass displaced vs. the time it took to displace it, so if you just let the saw do it's job, and make decent sized swarf ( it's a saw, not a grinder ) the pieces won't be hot enough to do any damage, and will be cooled down considerably after they've traversed the hose, being transported by cool air along the way.
Saw, don't "nibble"- the latter may produce tiny and very hot pieces of swarf, and ruin your blade as well as the profile in the process. It may be counter-intuitive, if you're accustomed to wood - especially when the sound kicks in.
Ignore this, and make chips - if you're producing dust you're not pushing hard enough..... Obviously if the saw bogs down you're pushing to hard.... [cool] Good luck.
EDIT: As the former poster mentioned:  ( and I failed to.... ) feed slow as the pieces are to be separated - It helps to prevent kickback, and the tendency of small pieces to veer off on unplanned ballistic trajectories...
Regards,
Job
Thanks a lot! I will post my experience probably this weekend!
Just one more question to get some kind of feeling for the aluminum blade! How fast does the aluminum blade wear off in comparison to the Universal W60 blade?
Aluminum is fairly soft, blade wear will not be a issue, a wear comparison between two different blades and materials would be imposable to quantify to many variables
Cute a whole load on 45mmx90mm extrusion to make a trolley for my KAPEX.. using the KAPEX with no problems (chips aren't hot either) I used the Festool alumium blade also, speed 4, took it steady. Juts wear glasses.
wow,  i never thought I'd see someone post about using a 1400 dollar saw to cut metal.  Don't you have an older chop saw to use?  I'd never use a kapex to do that.  not that you can't just wouldn't want to.
Why? with the right blade whats the issue?
Apgar:
Well you got me thinking! Although if Festool manufactures an aluminum blade...................and for the extrusions I need a pretty accurate bevel cut.
They make metal cutting blades for the TS saws as well.
I think solid surface would be harder on the tools then aluminum and they pretty much designed quite a few tools with ss work in mind.
I would cut it with my kapex if the need arose.
