Sanderxpander said:
Not doubting your 40 years of experience, but isn't WD40 flammable? And technically not a lubricant.
If there are no sparks...there is no fire. [big grin]
WD40 is a lubricant from the aluminum's perspective and it does work well. I don't use it because it can be messy. I prefer to use isopropyl alcohol instead because it migrates less and evaporates after 5 minutes. Again, you don't want any sparks with that stuff either.
Usually when drilling .060" Ø holes in aluminum the drill bit immediately gums up with aluminum and the chips are hard to clear. When using IPA for that situation, the drill produces tiny aluminum chips and there is no gumming up. It's just a pleasant experience. [smile]
