I have some cabinets to build and I would really like to use my TS55 with guide rails to pull this off. Cutting down big sheets is what I usually use it for then dimension it all down on the Table saw. I use the table saw because I like the repeatable results. Can someone who has used the TS55 do cut all the sides etc give me a brief overview how you go about it? I'm not a tradesman just a serious hobbyist. I've done my entire kitchen but like I said I only used the TS55 to break down sheets. In the long run I would love to eliminate the Table Saw and just use the MFT table and my TS55.
Any tips or advice would be great. My biggest thing is making sure all my sides are all the same size..not 1/32 off here or there etc. I like to use a 1" of foam on my work table 4X8 and cut the sheets on top of the foam.
Thanks in advance guys
Joe
Joe
