I'm asking advice about fixing the following problem:
I've got an ipe deck where the floor boards were installed with gaps that were too small or non-existent. This isn't a major problem, but when it rains, water drains off more slowly, and it gives slippery mold and mildew more time to grow than otherwise. The boards are attached to the joists with metal brackets. These brackets run along the length of the joist and are screwed into the joists and straight up into the deck boards.
So the point is that in the gaps between the deck boards there are no screws, or metal, or clips, but as they cross the joists they are just a hair above the metal brackets.
I've got the TS55 plunge saw and a 55" guide, and I'm thinking of lining the guide up along each pair of boards, and cutting to a depth of 25 mm. (The decking is 1" thick).
Do you think this is going to work? Can you think of something better? No matter what my plans, I suppose I'll end up nicking a steel bracket every now and then, so maybe I need to start with some sort of less expensive/utility blade. What blade would you recommend?
Thanks,
Will
Thanks,
Will
