Cutting steel with a circular saw
The blue end of Richmond County, NY
Has anyone tried this blade with an ATF/TS 55 saw?
freud-tools_2116_15969061
That is a 20mm arbor if the pic is too small.
Panasonic cordless circular saws have a 20mm arbor.
Shane  posted a link to a video showing the TS 75 cutting stainless steel here.
I haven't read of anyone using the 55 saws to cut steel.
Does anyone know what speed the 75 was running in that video?
I know dedicated dry cut saws run at around 3200 rpm in the
7-1/4" diameter so I'm guessing the 75 ran slower.
Does anyone know the correlation between speed numbers on the saws
and actual rpm?
Okay, I did my homework.
The TS 55 has speed settings from 1 to 6 with an rpm range of 2000 to 5200.
So...
1 = 2000
2 = 2640
3 = 3280
4 = 3920
5 = 4560
6 = 5200
The Panasonic saw that uses the 5-3/8" metal cutting blade runs at 3600 rpm
so the ATF/TS 55 saws should be set to around 3.5.
Thanks for doing the homework Michael, if you end up cutting some steel please report back on your experience.
