Dan1210 said:...only used for cabinet installs
... rarely drive anything over 2" with it,
Rick Christopherson said:Dan1210 said:...only used for cabinet installs
This is a light duty drill, but you are using it as though it was just a more compact C12. It's not, and it wasn't intended to be. The CXS does not have the MMC motor or MMC electronics. For the type of work you are doing, you need to pony up and buy the full size drill. Otherwise, you're just going to keep smoking the motor.
jmbfestool said:Average screw size for kitchen fitting is 20-30mm so I take it you can only screw 20mm or less screws with it.
Rick Christopherson said:jmbfestool said:Average screw size for kitchen fitting is 20-30mm so I take it you can only screw 20mm or less screws with it.
20 to 30 mm? I know you guys do things different over there, but are your cabinets made from cardboard or something? What part of cabinet fitting could possibly use screws that short? I use screws that short to secure drawer fronts to drawer boxes. Not for securing cabinets to walls. Even securing carcase-to-carcase, that is too short. I can't even think of an application where a 20 mm screw would be used during installation.
Timtool said:I have had mine for a year and a half now and use it daily professionally in combo with a T15, i don't think you are supposed to be able to burn it. It has a built in safety that cuts it out when you strain it. When that happens then you know your pushing it too hard. But even though mine does light driving work most of the time with the clutch set to rattle at torque setting 2-6, i occasionally drive 5x90 screws through beech with it which is borderline, but it doesn't complain.
Can you tell us more about what model battery it has, the newer more powerful one? Mine is the first 2.2(?) model.
I said i mostly drive with it on that that torque setting, but with 5x90 screws (with a 60mm pilot hole) i have to switch the torque off. When the battery is full it won't complain, but when it's near empty it will stop halfway.Dan1210 said:5x90 [eek] at torque setting 2-6? wow! mine would struggle to drive that, in fact with the torque setting that low it wouldnt even with an adequate pilot hole, i will check the battery specs i did buy it as soon as it was released.
Timtool said:......From what you are saying i suspect there is something wrong with your CXS, the electronics should prevent you from damaging it. It's not a light duty wimp, it has more guts than the Bosch 10.8 volts i had before.
The only thing that you could do to seriously limit it's longevity is to often drive screws in the second speed, i hope you haven't?
