atogrf1 said:I have about a half hour to kill before a meeting tonight. I am going to be doing at my local Woodcraft up the street.
I just KNOW that I am going to walking out of there with a CXS. I just know it.
OK, I'll bite... I'm buying a C15 (which I've wanted since I bought my C12 four years ago). So why is a CXS the perfect compliment to a T/C15? Why not just use a T/C15?GhostFist said:WARNING!!!! The CXS compliments a T-15 perfectly. Once you bit the cxs you'll see it's amazing capabilities and understand it's justifiable limitations. The T-15 works perfectly in tandem, in fact I've been interchanging the jacobs chucks between the two and am taken aback at how well they compliment each other. You will buy another FESTOOL drill after purchasing the CXS.
Dan Clark said:OK, I'll bite... I'm buying a C15 (which I've wanted since I bought my C12 four years ago). So why is a CXS the perfect compliment to a T/C15? Why not just use a T/C15?
Regards,
Dan.
fidelfs said:Dan Clark said:OK, I'll bite... I'm buying a C15 (which I've wanted since I bought my C12 four years ago). So why is a CXS the perfect compliment to a T/C15? Why not just use a T/C15?
Regards,
Dan.
- Price
- Size
- Ergonomics
- Weight
I am very surprised to find that I am using the CXS much more than my T12, but I'm not building decks or anything like that.Dan Clark said:fidelfs said:Dan Clark said:OK, I'll bite... I'm buying a C15 (which I've wanted since I bought my C12 four years ago). So why is a CXS the perfect compliment to a T/C15? Why not just use a T/C15?
Regards,
Dan.
- Price
- Size
- Ergonomics
- Weight
OK, you talked me into buying both! (Pushy bugger. [smile] )
Jesse Cloud said:I am very surprised to find that I am using the CXS much more than my T12, but I'm not building decks or anything like that.
GhostFist said:perfect drill for that job, last thing you want is a full sized drill while crawling on your back (if they're the crappy sort of hidden fasteners I usually end up installing).
Ken Nagrod said:Brice, I have to ask since I've seen this before. You scribed the deck boards around the tree. Why go to all that trouble when you need to leave a decent gap like you did so you might as well make it a smooth curve, as smooth as possible with the jigsaw?
Sorry for seeming picky, but I am curious since I've seen others do that too.
EvilNuff said:I have a similar question...why wouldn't you leave a bigger gap? The work looks fantastic but that tree's going to start pushing those boards in a few years.
Brice Burrell said:Simple answer Ken/Evil, the client has a cat that got stuck (several times) crawling between the old decking and tree while casing chipmunks. The client asked for tight fitting decking to spare the cat the embarrassment. Right now there's 1 1/2" gap but there's room to enlarge it in the future.
