RustE
Anyone found a good method for storing D150 abrasives?
One of my ideas is to use the Tanos dividers to make compartments in a Systainer 2. The layout would be two stacks of D150 abrasives in the back with some hand sanding abrasives in the front. Rough estimate is the 120mm dividers should hold 80 pieces of D150 abrasive in each stack.
Most reviews I found for the SYS-STF-D150 (item 497690) do not have favorable comments for the insert design. Which is disappointing because I like the Systainer 1 with the insert for D125 or 80x133 abrasives.
