MichaelW2014
- Jan 3, 2014
"Preparation for Dado tooling up to 19.5 mm width"
jesus, you could really debrain yourself on this puppy.
HowardH said:I have the Felder dado stack for my Hammer K3. No guard. Works like a champ. Very clean sides and bottom. Not cheap, tho. I ordered the setup when I spec'd the machine.
Lbob131 said:When I start up my two piece Felder dado/groover set, my mind is set at ease knowing the new arbour is designed for the job at hand. High quality machined steel and heavy set and runs very smooth on the poly V belt.
The arbour shaft is 35mm diameter. Similar to the drive shaft on a car wheel.
There's no compromises.
The thought of it shearing the shaft and jumping up out and going air borne never enters my head. ;D
dutchie said:Try the Bosch GTS 10 XC. On another forum I read how someone ordered some parts from the Bosch 4100 (which is in a way the US version of the GTS 10 XC) and used this to fit a dado stack on his GTS 10 XC. Don't think this kind of operation will be covered with warranty though
See > http://www.routerforums.com/tools-woodworking/38123-bosch-gts-10xc-dados-thanks-rcp16.html
jacko9 said:I had a Swiss made Inca Major 10" table saw for over 20 years and safely used a dado stack on that saw without any issues.
Jack
MichaelW2014 said:Sounds like a fantastic little saw.
I don't think i would ever cut a dado bigger than 2 or 3 cm, so 18mm to 20mm sounds good.
I'm impressed it had a mortiser on it.
MichaelW2014 said:yeah, i saw that one. but I am living in greece. i have to find one in the EU to prevent paying 20-25% import fees on top of the shipping cost. thanks
