T tsmi243 Member Joined May 16, 2015 Messages 536 Nov 7, 2022 #21 Packard said: If a road sign says “no left turn” and you turn your steering wheel to the left to make a u-turn, did you make a left turn? Click to expand... Just do the u-turn to the right, problem solved.
P Packard Member Joined Nov 6, 2020 Messages 5,758 Location Hudson Valley, NY Nov 7, 2022 #22 tsmi243 said: Packard said: If a road sign says “no left turn” and you turn your steering wheel to the left to make a u-turn, did you make a left turn? Click to expand... Just do the u-turn to the right, problem solved. Click to expand... To make a u-turn to the right, you pretty much have to be traveling on the wrong side of the road.
T tsmi243 Member Joined May 16, 2015 Messages 536 Nov 7, 2022 #23 Packard said: tsmi243 said: Packard said: If a road sign says “no left turn” and you turn your steering wheel to the left to make a u-turn, did you make a left turn? Click to expand... Just do the u-turn to the right, problem solved. Click to expand... To make a u-turn to the right, you pretty much have to be traveling on the wrong side of the road. Click to expand... But the sign says no lefts, what else can you do?
P Packard Member Joined Nov 6, 2020 Messages 5,758 Location Hudson Valley, NY Nov 7, 2022 #24 My point was that simply turning the wheel to the left, does not mean you are making a left turn. Likewise, using a dado blade, does not mean you are cutting dadoes. I use a dado blade to cut tenons, rabbets, grooved, slots, etc; not just dadoes.
T tsmi243 Member Joined May 16, 2015 Messages 536 Nov 7, 2022 #25 Packard said: My point was that simply turning the wheel to the left, does not mean you are making a left turn. Likewise, using a dado blade, does not mean you are cutting dadoes. I use a dado blade to cut tenons, rabbets, grooved, slots, etc; not just dadoes. Click to expand... This is fun [popcorn]
