I'm adding a deck onto my shop, and I'm finding the TS55 a bit unwieldy when used without the table and the guiderail. Any suggestions?
For example, trimming the joist ends once they're installed (to match up with angles), or trimming off post tops. It is hard to line up the saw to know where the cut line is. It doesn't seem practical to lay out 12' and 14' joists, mark them, remove them and then carry them over to the two tables needed to support long lumber (made even more difficult because there isn't a flat surface to place the tables, which is why I'm building the deck in the first place...) and then put them back in place.
I don't think I'm a good enough engineer to pre-cut all the lumber and then have it all perfect when I go to assemble it. (maybe if I had two helpers and a laser level... but I don't).
I thought about cutting down a guiderail to 12", just so I'd have a short piece to line up with for cutting these (and then clamping the baby rail to the lumber), but I sort of hate to ruin a $59 rail if there's a better way.
