Hers a different way for a decorative Domimiter.
After cutting the miters on the sides, glue and clamp. After 10 or 15 minutes when it has grabbed and can be used carefully with no clamps, Domino in a measured staggered fashion (use index pin) down the sides and insert Dominos, when dry sand or plane flush, then using the little jig bellow Domino to "fill the gaps" ;D
The little jigs width fits perfectly between the pins so centering is automatic. I know its a bit over the top, but its all just good fun ;D
