For sale is a Delta Universal Miter Saw/Planer stand which has only been used in my basement shop and never outside so I would call it in like-new condition. I purchased the stand new in March 2007 and paid $230. Overall dimensions are 38.5" x 20.7" x 9.8" (folded)
Has 3 positions (including folded) and uses a pneumatic piston to aid in raising and lowering. There is an adjustable roller at each end of the stand that can be adjusted side-to-side and up and down. Each roller is 17" from the center. Fully open, each roller is 44" from the center, a total of 88" of support. There are four adjustable hold down points, which should accept just about any miter saw or planer. For tools that do not fit on the connectors, mount the tool on ¾" plywood and attach the plywood to the stand.
When opened, the stand's wheels are on the ground allowing it to be moved in the open position. Wheels are 8". Construction is heavy tubular steel (.070). This stand is strong. Delta rates it at 200 lbs. capacity. Light gray paint with black top.
Offered at $120
I can't ship this but will drive up to (say) 150 miles in any direction from my home in Batavia, Illinois - about 45 miles directly west of Chicago - and meet you if you'll add $25 (negotiable, depending on distance) to the price above to cover my gas.
Offered at $120
