I have mostly built face frame cabinets. However, this time I am using 16" wide uprights with the 32mm system holes already drilled.
So once the cabinet is built I can select two holes near the top and two holes near the bottom for the mounting plates.
The assembled box will look like this with the hinge plate in place:
The best way I have found is illustrated by this image. Though they show the centerline, they don't show how to derive the centerline.
Are there any better systems? Blum makes a transfer gage but it costs about $120.00 and seems pricy for mounting four hinges.
I also have this Blum template for locating the mounting plate after drilling for the hinge, but I will be reversing that sequence here.
