Fastcap "Little Lipper" Installed on OF1400 - Zero Modification Required!
TinyShop
I've been meaning to upload this for a while now...
I've found an elegant solution to how to fit Fastcap's "Little Lipper" router outrigger accessory (for flush trimming operations) onto the OF1400 - no modification to the router needed. As I understand it, this approach should apply to other routers as well (at least any that already feature at least one stock threaded hole in the base).
Here it is:
That tiny threaded adapter in the bottom right of the image is where all the magic happens.
Here's a close up, showing the 1/4-20 hex mounting bolt that ships with the Little Lipper (use of which relies on a destructive through-hole in the router base) and the threaded 1/4-20 x M6-1 adapter (which makes use of the existence of the stock threaded holes - only one needed - in the base of the OF1400):
Here it is installed in the Little Lipper:
The large diameter fender-style washer that also comes with the Little Lipper will not needed.
As a regular user of the LR32 system I am familiar with installing and uninstalling it's guide rail sled onto/off-of my OF1400, a task which is facilitated via the use of two M6 x 1 bolts. I also knew that the Little Lipper relies on an internally (female) threaded hole cut for 1/4-20. The trick was finding a conversion bolt that converted from one thread to the other.
Having now relied on this solution in the course of milling a couple hundred lineal feet of solid maple edgebanding, I can report that it works so well that it's honestly as if the disparate pieces were an OEM-offered combination.
You will note in the above photo the installed chip catcher - it works perfectly in conjunction with the Little Lipper - the result being that zero (and I mean zero) airborne dust is produced. At least that's what I experienced while using the router to flush trim ~1-inch thick (5/4) and 15-20mm wide reclaimed maple milled into solid edge banding and glued into domestic, cabinet-grade, 18mm-thick unfinished domestic birch ply using Whiteside's "Ultimate Flush Trim" spiral bit (UDFT9112). [Side note: I used HValley Tool's - formerly Eagle America - edge banding router bit set (190-2045) to mill the material.]
Any chips/shavings not captured by the stock dust collection just falls harmlessly to the floor (none of which first plows you in the face). The chip catcher acts to prevent what would otherwise happen if you tried this operation without it (all the escaped chips - and these would be ample - would end up pounding you directly in the face).
This is an impressive marriage of stock tool and after-market accessory that I think anyone would be impressed with, especially since, in practice, zero modification to the router is required.
To elaborate on that last point, the icing on the cake is not having to drill a mounting hole into the intricately honey-combed base of the OF1400. As anyone who has ever removed the stock Masonite/hardboard sub-base plate from this router can testify, there's literally only one sub-postage-stamp-sized area where there's enough solid real estate available to be able to drill the otherwise necessary through-hole.
You'll note on Fastcap's product video (where Paul Akers showcases the Little Lipper installed on an OF1400) - pause the video and zoom in - that where he has the Little Lipper installed is literally the only place it can be installed on this particular router (if you go the undesirable route of drilling a hole through the base of the router). This is one of those "options" that if not accomplished perfectly results in lots of heartache. Best to avoid it altogether!
I'll admit that as soon as I observed this dilemma (and how poor a candidate the OF1400 is for use in conjunction with the Little Lipper, assuming there's a burning desire to drill a through-hole into a perfectly good router base) I just knew there had to be a better solution.
So, after some internet sleuthing, I found the following:
https://www.ebay.com/itm/175902542664
While the shipping time is lengthy (at least for us coddled "first"-world'ers), for anyone planning ahead, this ~$7 solution (I bought two just to have one in spare, so my cost was just shy of US$12) - at least for anyone seeking to use the Little Lipper in conjunction with their OF1440 - is a no-brainer. This high quality nickle-plated threaded adapter fits the bill perfectly.
Note during use - a dab of blue loctite on the 1/4-20-end of the adapter aids in keeping the adapter fixed in the internally-threaded rod that forms the backbone of the Little Lipper. Absent this application, you'll find that the M6-end of the adapter "sticks" in the threaded hole in the base of the router (which is aluminum or magnesium - it's "soft" relative to the steel adapter), requiring you to have to first unscrew the Little Lipper from the adapter (that steel-to-steel connection is what typically breaks-free first) and then grasp hold of the thin shoulder of the adapter with a pair of pliers to nudge it loose from the base of the router. Red loctite would be the final solution to this minor problem but since I want to preserve my future ability to fit the Little Lipper to other routers, I opted for blue threadlock.
Also, while the OF1400 features two threaded holes in its base, the ideal hole to deploy is the one located on the side opposite the dust port (IOW the same side with the knob). Installing the Little Lipper in this configuration is ergonomically excellent and makes for a well-balanced tool (the handle is typically pointing right at your stomach, as is the dust port - compare this to the Paul Akers approach which results in the handle and dust port sticking straight up - not very ergonomic). Set up "my" way it's an total pleasure to use! [Note - the router will need to be rotated such that the handle is facing directly away from the user in order to get at the last few inches at the far end of the panel being trimmed - this works fine in practice since it need not be a climb cut assuming the work piece is to the user's right. Of course, a little bit of climb cutting is required but its the short area closest to the user at the near side of the workpiece, when the handle is pointing at the user, so that's easily accomplished.
Before:
...and after:
So, in summation, this combination of stock router and two after-market components (the latter constituting a total outlay of ~US$50) - a marriage made in heaven - works perfectly for what I need it to, which is to allow me to plow through all the hardwood material sitting proud of the cabinet panel that I'm edgebanding in a single pass.
This is the quick-to-setup, remarkably-effective-in-use and far-cheaper alternative to what Festool will sell you which is it's (by comparison) rather cumbersome and unwieldy (in marked contrast to the engineering simplicity of the Little Lipper) and far pricier (total cost well more than three times that of the Little Lipper/threaded adapter option) trio of:
https://www.festoolusa.com/accessory/486058---up-ofhttps://www.festoolusa.com/accessory/486052---wa-ofhttps://www.festool.com/accessory/routing/machine-accessories/stops-and-guides/486242---sf-of*
*plus, some modification to this accessory will be needed to get it to work with the OF1400 - it's designed for the OF1010 but by adding a longer mounting bolt it can apparently be made to fit the OF1400 (not advising anyone go this route, mind you).
I honestly couldn't be happier! :)
Nice solution... when I saw the Little Lipper long ago, I considered getting one, although the MFK-700 mostly takes care of edge trimming. This would allow for bigger bits if needed.
woodferret said:
Nice find.  Now someone just needs to give us a clear chip deflector.
No doubt. Given the opaque nature of the stock deflector, one does approach the cut a bit blind.
That said, I quickly adopted the technique of taking a quick peek at the position of the bearing relative to the reference surface by craning my neck and viewing it through the opening that, if your setup requires it, allows the head of the allen bolt (which fastens the bearing to the shank of a flush trim bit) to protrude slightly past the inside face of the chip deflector. Then, after a while, I just started to trust my ears and the feel of the bit - it's not really necessary to take multiple passes with such a powerful router (relative to a small trim router), so I just let the weight of the pivoting router apply even downward pressure until I feel the slightest resistance (indicating that the bearing is touching the reference surface) and then plow merrily away. The bulk of my focus is on keeping firm pressure on the Little Lipper (to prevent any tipping) and also ensuring that the base of the router stays tight up against the edge of the work piece to limit skewing. Like anything, the more cuts I made the better the results.
You bring up a good point though - given that Festool frequently loves to show off its dust collection prowess via reliance on transparent dust and blade shrouds, it's funny that they chose black plastic for the OF1400's chip deflector. Maybe a future upgrade can substitute transparent plastic. Or perhaps Fastcap can come up with something universal as an accessory for the Lipper. The way the OF1400's orbits all the way around the arbor makes it very useful for flush trimming - a clear version would be an improvement for sure.
As the shroud for the 1400 and 2200 are basically then same, I would guess this is for safety reasons given the much more powerful and aggressive cuts you can take with these, especially given the massive cutters you can use. I could be wrong though.
