Dave Ronyak
- Jan 23, 2007
Recently I purchased a DeWalt T-Square attachment for Guide Rails, and a pair of DeWalt's "quick clamps" for securing a Guide Rail. Both DeWalt products fit Festool's Guide Rails. The clamps also fit the channels in the side rails of Festool's MFTs but not the holes in the MFT tops. I thought these might be handy when working at a jobsite without my MFT for cross cutting boards, panels and sheet goods.
Shown in the photos below is the packages for these products.
Here is the T-Square attachment itself. Note the short piece of metal with the two black screws. That component is a dovetailed key, raised above the surrounding top surface of the housing. It should be exactly 90 degrees to the machined face of the housing. Mine was not.
Here is the DeWalt T-Square partially mounted on my LR 32 Guide Rail.
I checked its fitment to all of my Guide Rails and found it to be a tight slip fit on most, most loose on this LR 32 and the 1080mm Guide Rail mounted on my MFT 1080.
Here's the view from the underside, with the DeWalt T-Square fully mounted on my LR 32 Guide Rail. The black knob is used to secure the T-Square in position. When tightened, the dovetailed metal protrusion is wedged within the channel of the Guide Rail. This simple clamp system works well.
All appeared well until I checked this assembly for squareness against a pencil line drawn with my 18" Precision Carpenters Triangle. The plywood panel shown in the photo has straight edges that were cut with my TS 55 on a Guide Rail. There was about 1/32 error across the 12 inch width of the panel. I rechecked this several times. OK for some work, but less than my goal. I repeated this check with 3 other Guide Rails, all came out the same deviation and in the same direction.
I fixed the error by disassembling the T-Square and judiciously filing the sides of the metal piece that has the dovetailed key that grips the Guide Rail channel. I did not remove any material from the dovetailed key. I removed material from the base of the key so it could be slightly rotated within the recess molded into the body of the T-Square. This required several iterations, including slightly reaming out the screw holes that attach this dovetail key to the housing of the T-Square.
The result was no discernible deviation from the 90 degree pencil line drawn with my precision triangle square.
Dave R.
Dave R.
