pingvinlakrits
- Oct 2, 2007
Topic has been up before but I never really got much of a response to my solution for an added grip.
FOG:ers probably don't think it is fancy enough.
http://festoolownersgroup.com/festo...domino-df500-frankengrip/msg395480/#msg395480
I have used it a few years now with zero issues and this very day I was joining acoustic trim/panels and really enjoyed my add on grip. It really saves the underarm from fatigue and for drop down plunges it adds stability. It is rock solid and after a few years use and abuse it hasn't shifted a bit even though I swing it around by the handle all the time.
Horizontal plunging works the same and I actually think it works even better since the forward momentum really pushes the Domino against the fence at the correct angle whereas you might tilt it up slightly grabbing it down by the cord if you are not used to the machine or simply not careful enough.
After comparing my unit to my colleagues unmodified unit I can say that I think the Domino DF500 is ergonomically flawed.
I also have the Domino XL 700 and it is heavy to handle but for actual plunging / mortising I prefer it over the DF500 - that is before I modified it to make it more like the bigger sibling. I was going to try to make a fancier handle but I never got around to it and after a few thousand mortises after adding the grip I am reluctant to change anything since it simply works so well.
