Today my new purchase, the Dictum low angle block plane with adjustable mouth was delivered at work. It's basically the Quansheng block plane in Dictum's signature light brown colour and the casting has a little "D" next to the knob for the mouth plate. The first thing I did (after cleaning it of course) was check it for flatness and squareness. Both were perfectly acceptable out of the box but like I do with all my planes I stuck down a piece of 320 grit wet and dry to the table of the shop jointer and flattened it until it was dead flat. That took me about 30 seconds. The sides were a little bit out of square but that doesn't bother me since I don't use block planes for shooting. The only thing left to do was break the edges. Then it was on to the blade. It's a very nice, 3mm thick, SK4 carbon steel blade @ 62HRC. The first thing to do was re-grinding the bevel to 28 degrees which results in a total angle of 40 degrees. On to my my trusty King 1200 and it showed me the back of the blade is slightly hollow, just the way I like it because it speeds up the work on the back. 30 seconds was enough to get the edge of the back completely flat. The next step was polishing the bevel on the Sigma 6000 with took just a few passes and removing the remaining burr by doing a few strokes with the back on the Sigma 6000. I also have to mention the bedding of the blade which is very well machined and nice and big for maximum support. The threading for the depth adjuster knob is also fit for purpose. it may be a bit on the coarse side but still more than capable of very fine adjustment. I actually like that it's a bit coarser because it requires less turns of the knob.The backlash is also minimal, just over a quarter turn. All in all this is very nice block plane and very good value for the money. (€57)
So why did it buy it and how does it perform? Well, the Veritas low angle block plane is my all time favourite plane but for some things it's too wide. Lastly the performance is what I would expect it to be from this plane. There's no blade chatter and the heft of the plane helps in pushing it along. If I have to think of something to criticise it would be that it's just slightly too long. For me the length results in me having to stretch my hand a bit more to place my index finger on the knob for the adjustable mouth. But it's certainly not a deal breaker for me, the ergonomics are still just fine. I'm just used to the flawless Veritas.
